I'm really not satisfied with my Ford F350 SDC headlight bulbs!! I need a BRIGHTER bulb suggestion that won't break the bank and not have to add ballasts and rewire the circuit - any suggestions??
you can look on amazon, i have had pretty good luck with HID light in both of mine trucks. i had a 1985 f 250 and now i have a 92 f250, hope this helps
I replaced my normal bulbs with Sylvania Silverstar Ultra bulbs. The results are not earth shattering, but they are noticeably brighter.
I haven't had much luck with Silverstar Ultras. Very carefully installed and one went out after 3 weeks. Reviews show others having similar experiences.
Get the 80/100w bulbs from Amazon. I have them on my previous and present trucks - better viability and no blinding effect to upcoming traffic.
These do offer good light but will eventually melt the wires and connectors to your lights. More power, more current more heat. Took almost a year for me to have problems. The LED bulbs are what I run now. A noticeable increase in light output without blinding oncoming drivers.
Rjm - didn't you have to change out some components/wiring with the HIDs??
Just make sure you buy the correct one for you truck and it was plug and play, it was pretty simple to do on both trucks. I will not have a truck with out HID they work great. I also have a LED light bar that I use but only when off road.
