are all 300 cranks and rods the same?
Old 03-24-2015, 11:58 AM
bmwcarl's Avatar
bmwcarl
bmwcarl is offline
I'm going to be putting together a 300 for my 72 F100 and will be assembling the parts from different sources. Does it matter what year crankshaft or connecting rods I go with?
Old 03-26-2015, 01:16 AM
fordman75's Avatar
fordman75
fordman75 is offline
The 65 and 66 cranks used a different main thrust bearing. After that they are all interchangeable.
For the rods the 65-67 rods used a .912" piston pin diameter. the 68+ rods used a .975" piston pin diameter. I believe the early rods also had oil squirt holes which made them weaker then the later rods.
Old 03-30-2015, 04:20 AM
trozei's Avatar
trozei
trozei is offline
You have it backwards. 1968 saw the introduction of the oil hole which is undesirable for performance applications.
Old 03-30-2015, 01:22 PM
fordman75's Avatar
fordman75
Thanks for the correction. It's been around 10 years or so since I tore into a 300 that deep. I knew it was one of them. Now I have to check my parts hoard to see if I have any early rods.
Old 03-30-2015, 06:58 PM
trozei's Avatar
trozei
trozei is offline
I have C5AE pre-'68 240 rods in mine.
73FOMO
09-17-2005 07:20 PM
malync2
07-29-2005 05:13 PM
St_alfonzospancakebreakfa
04-04-2004 03:20 PM
rtbstrd
05-03-2002 06:58 AM
rfgre
01-14-2000 05:31 AM
Quick Reply: are all 300 cranks and rods the same?
