Battery Ground find.
We have been having an issue with weak starts. Never failed just sounded weak. This weekend I found that my Drivers side battery ground had High resistance, like 6 Mohm. I took the connection off the frame and found that it had built up dirt and grime and wasn't making a connection. Cleaned up the ground reconnected everything and all is good again (.05 ohms which is about as good as my meter gets). Sounds better when starting now. I wonder how long it has been like this. Had to be a VERY long time. Probably what killed my first set of batteries. Only one battery doing all the work. Plus probably why I have had some Alt problems also.
Great tip! I guess I need to trace out my grounds and check them out to see how clean they are.
On another note, I have plans to upgrade my charging system with larger charging and grounding wires in addition to adding a high output alternator. Guess I could work on all of this at one time!
Vernon Myers
02-21-2016 05:28 PM
ChrisGray91
08-25-2014 01:54 PM
mattcad
40
07-17-2013 11:02 AM
