Another one followed me home
This thing followed me home this weekend.
Quite literally
(check out those super awesome KM2's-Thanks FTE and BFG).
What I know about it:
E99 F350 CCLB 4x4 Lariat.
Auto trans
Has been sitting for about 7 years
Has some sort of electrical issue
The starter is sitting on the passenger floorboard
The engine bay is dirty to say the least
It has a metric crap ton of miles on it
The story is that it was used to haul bulls from Central California to Texas quite regularly. It was parked with some sort of electrical problem, and now the owner has been MIA for quite some time. My plan is to either get it running and sell it, or part it out. After seeing the odometer(after i got it home) I am more inclined to try and get her back on the road towards the million mark. It will take some time to get paper work on it, so I won't be putting much if any money into it for a while but I do plan on throwing a couple batteries and the starter back in and see what happens.
Quite literally
Auto trans
I plan on pulling the intake until I stop finding dirt, I doubt there is much dust past the turbo. Drivers seat is torn up, passenger seat is in pretty good shape and the back seat is perfect. The drivers rear tire blew out at some point and damaged the bed, the tailgate is beat, and the pass tail light is broken along with some bed damage there.
So far I'm into it for a grand, not too worried about getting my money out of it.
Quite literally
Auto trans
Quite literally
Auto trans
Finders keepers!!!!
Smokie
Finally took a look at the truck. No communication with the PCM. No MIL, WTS, the OD off light stays lit very dimly. 5 amp pcm fuse was blown, replaced with no change. All powers and grounds good at the PCM. Pulled the PCM apart and there is a burned spot right where pin 97 (B+) goes into a cap, also a burned component down between the two transistors on the chip port end of the PCM. Now I'm trying to find a cheap PCM to plug in and try, I don't want to use the one out of my '00 in case it fries again.
Any one seen a PCM fry like this?
BTW, the first section of the intake boot had some dust in it, the rest of the intake and the turbo are clean. Compressor wheel is in good shape, not even considering the mileage.
any weird aftermarket wireing under the dash or anywhere else on the truck?
I'd be leery of plugging another PCM in as well. You might try giving one of the larger volume tuners a call, I'm sure they have seen the guts of thousands of pcms.
