My 56 pickup build thread
Received 4,135 Likes
on
on
The next thing I wanted to do was mount the cab on the frame and had tried ordering the rear mount brackets but was told they were not available so had to make my own
then it was time to bring in the frame from hibernation
I used my engine hoist with a simple cradle I made from some 4x4 timber to lift the cab high enough to roll the frame under it
Half hour later it's sitting on the frame, worked out very well
next was stripping off the rear suspension to get ready for the TCI kit that I purchased
I picked up an 8.8 rear differential from a 98 Ford Explorer from the wreckers.
Then I proceeded to install the front cross member, it's a Heidts superide ll.
This is where I am at at the moment, I am waiting on arrival of an oil pan so I can install motor mounts for the 351W and C6 transmission.
on
on
on
on
on
Nice work John, the frame work is always my favorite part of the build, maybe because the welding is just so much easier to me.
Are you going to leave the original trans mount out or do something there. I have taken mine out because it blocked the trans pan and I would have a difficult time servicing it. I wonder about the structural support loss. I did do my trans mount almost identical to yours. Another question are you going to have to fab up a trans tunnel or did ya mange to keep it below?
on
on
John, very nice work! you may want to consider some type of brace near the top of the frame. I noticed on mine the frame was very flexible when I stood on the running boards till I tied the tops of the rails together.
#28
on
If you notice on the picture of the motor mounts you can see where I cut the original cross member I left some short sections, my plan was to make another cross piece from 1/4" plate to bolt to those pieces. I think this should put back the original strength, I'll know if it works once it is in when I unbolt the new cross member and post what I find. If it don't work then will do as you suggest with some bracing on the top of the frame.
#29
#30
on
