is there supposed to be a gasket between the starter and the trans housing???
Ok, starter fried. easy enough, 3 bolts off and 2 electrical connections.
BTW FWIW, I used a 13mm long socket, a 6" extension, a u-bolt swivel, mounted that to the top bolt using feel, then attached my socket wrench. Didn't remove the electrical connections first. Worked just fine, wasn't a PITA.
ANYWHO, while removing the starter, a black piece of plastic fell on my face (had glasses on, as you should while looking up).
It appears there is a black plastic gasket, or seal, or shim or something that is stuck to the trans housing. It has the holes cut out for the bolts, so it looks factory. And its broken now... HOWEVER, there is NOTHING on google, o'rellys, autozone or ANYWHERE I can find that says there is a gasket there. Or seal. Or shim!!!! What is it called? Do i need it? Is it factory? Or can I just scrape it off and mount metal to metal?
Thanks
Thanks
put the starter back on; started; went clunk clunk clunk. Shut it off immediately... Didn't retract? Not square? I didn't remove the remnant plastic; I just made sure it was tight. I'll get to scraping that junk off tomorrow when I have daylight. I don't have the patience to work in the dark...
ok, so remounted it. I couldn't even scrape the plastic junk off... So i took a piece of the stuff that fell off and used it as a spacer to align the starter, but it still wasn't good enough apparently. It didn't clunk this time, but there was still noise like it wasn't disengaging. More of a whine. So, the best I can guess is I'm going to have to figure out a way to get it all completely off before it's going to seat properly, THEN I'm going to have to figure out if it's supposed to have a spacer, and find a place to buy that. Or I have a bad starter... We'll find out tomorrow.
Forgive this question, by what exactly is the starter mounting to? What is it called? Flywheel housing, transmission housing, bell housing... and does THAT parts schematic have a gasket listed for IT?
Fly wheel housing....don't know if there is a gasket listed there but highly doubt it, I've never seen a gasket behind ANY starter.
