Question about idle and driving rpm
1) Timing. Do you have your vacuum advance connected to manifold vacuum? If so, possibly your vacuum is dropping enough when you put it in gear that your retarding the timing. You can try with vacuum advance disconnected (you would want to verify base timing is correctly set without vacuum connected)
2) Is engine running lean? Pull a spark plug as see if engine is lean ( is color white) also an excessively wide plus gaps or worn out spark plugs/wires can cause idle speed problems.
3) torque converter problem? You can do a "stall test" and see if there are any signs of converter failing.
4) Does your truck have an EGR valve? If so, maybe it's leaking some.
5) Did this problem just start after you replaced the carb? Need more info on this.
6) Did you remove (leave off) the idle speed solenoid or dashpot when you replaced carb?
Zazoos
10-07-2016 09:21 AM
NW 150
18
04-03-2012 08:05 PM
LANGEVETTE
08-10-2010 12:51 PM
smoke n tires
12-15-2004 03:08 PM
