customizeing ford aerostar vans
I'ts me
Well i just got started on my project, The doors are off , and the termites have lost there home, The rocker panles looked like swiss cheese , the bottom of the doors wont be a big problem
went to the local junk yards(or should i say recycle yards )
got what i needed for caddy tail lights, I been thinking about welding up the back door an fill it in and put in a third light, and
maybe put in a new location for the rear tags, you know kinda side ways that way i can install a rollpan on the rear. well that gives you all enough to laugh about for a while, but this will keep me off the streets an outa the bars
Have a good day!
Shooter
Have a good day!
Shooter
I saw something on "Trucks!" (cable show) that may interest you for the tag. It's a small metal box/tray that allows you to recess the tax in whatever position you want. It has a template you cut out of the body panel, then you put it in the hole, weld the edge, and paint.
Thanks rickm5
I'll be dadgum if you wasnt right, i just didnt think that back door was fiberglass,its so darn heavy,well that makes the caddy lights go where the tail lights are, i will have to fill in where the lights are an then cut the new lights in, I aint about to mess with no fiberglass ever again, the front doors are shaved working on the side door.
Keep the shinny side up!
Shooter
Shooter
on
1 Post
[QUOTE]Originally posted by rickm5
[B]i saw a 89 or 90 aerostar with a cone shaped air filter on the end of the air intake , where my air filter box is. anyone else done that? does it help mpgs?.
No, the cone filters do not help any, and actually hurt performance.....the underhood area of the aerostar is rather cramped, and gets very hot in there. You then pull in that hot, underhood air, and your engine performence suffers....I did some airbox mods to my 95 4.0, it pulls in underhood air, and now, when it is hot, it runs like crap. I pulled the hood off for some paint touch up, and drove it around like that, and it ran like it had an additional 40 hp....I will be redoing the airbox, and adding a outside air intake tube.....I already knew that ram air setups work, I just had no idea how much hot air would affect the way this particular engine ran (pinging, etc).......
I've been giving ram air a lot of thought lately but I'm worried about blowing up my engine. Are there any engine mods that I need to look at to accomodate this extra hp? I'm looking at fabricating up a hood scoop similar to that on the Subaru WRX and then running the air through a K&N Filter. Thanks.
David
1989 Aerostar Eddie Bauer - 136,000 km
David
ad16
Aerostar
15
12-22-2016 11:55 PM
