I have a 1997 f350 7.5L and Im looking for the 2 studs that connect the EGR to the throttle body. no part store around me carries them. anyone have or know where I can get some? thanks
The proper length bolt will work as a suitable replacement. Otherwise you can make your own studs by cutting off the heads of two bolts, or by using threaded stock. I can't recall if it is 5/16 or 3/8.
