So, I just crawled under the X to scrape all the rust off the hitch to do the annual spring repaint. While scraping the loose rust a hole developed on the bottom tube about three inches long by about a quarter inch wide. I thoroughly inspected rest of hitch and all seems solid. I really hate rust! I know it will do nothing but get worse, but my question is, should I replace the entire hitch, or do I still have a couple more years left in it? If they were easier to find and not as expensive, I would just replace it, but I had a hard time finding a replacement two years ago! Thanks in advance for your opinions!
Nope. It is now junk, unless your only going to put a bike rack in it. Mine doesn't have a hole in it, but it is rusty. I bought a Curt hitch for the X, they now make hitches for them.
If you are towing in the Peach State let me know your itinerary, so I can stay home.
Don't worry, won't be towing until I replace it! Not that it matters down there, last March when I drove through Atlanta on the way to Mickeyworld, I couldn't believe the drivers! You either go 85 or 40....nothing in between!
I picked mine up from auto anything. $139 with a code and free shipping.
I'll be putting mine in, in a couple weeks. I'll be cleaning up and repainting the skid plate along with the frame rails.
Just checked autoanything.com (thanks tor the tip) and quote was $232. You got a screamin deal! Going to check local Radco to see if thay may have one in stock, but probably going through autoanything.
Do a google search for a coupon or check any of the diesel magazines..might can get it cheaper.
Ya, it was a Christmas time deal. couldn`t pass it up!
Use current coupon code lucky20 for 20% off so its 185.59 shipped
