Intermittent SES light. I'm stumped!
Hey everyone! I'm brand new here. Live in Alaska. Bought a 99 7.3l a few weeks go. 250k miles. Buyers inspection from reputable shop found cyl #5 & 8 high low open. Cleared codes and passed run ability test. Could not replicate. So I bought the truck. Paid $6k for it which was a steal. SES light comes on intermittently for a few seconds and goes back off. Mainly when I'm just leaving the house. Once it's fully warm the SES light mainly stays off. Snap On reader today says bad ICP. Checked icp and no oil in connector. Has a slight miss on idle. What do u guys think?
AkSam good talking to you tonight, maybe we will get a chance to read your codes with my AE Saturday. Hold on tight, these guys around here will have some suggestions for you soon, they are very helpful and know their way around these 7.3's like the back of their hands.
There is a 42 pin connector above the drivers side valve cover. There is a bolt that hold it together. Pull that connector and make sure all connections are clean. Also look under that harness where it passes over the valve cover for chaffed wires. If you search "42 pin connector, there are numerous threads on ohming out that connector while you have it apart to check the condition of injector harness connections.
on
I have had this same problem when the engine is cold and the EBV is closed. It has throws a SES light but is not on long enough to store it. There have been a few codes that have stored one was a TPS code and the other an ICP lower than desired. I don't think I would be too concerned about it as long as you don't get a code after it's at operating temp and the EBV is open fully IMO.
That actually makes sense. So you're thinking it may just be sticking? How would that trip an icp code though?
on
I'm still trying to figure this one out. I think it has to do with the ICP commanding more pressure but can't get it because of the conflict with the EBPSensor. I don't know much about the mapping of all the sensors and how they all work together so that's my best guess.
ICP has nothing at all to do with the exhaust pressure regulator operation. That operates off of the lubrication oil side of the circuit.
P1280 - ICP circuit low input
Possible causes:
-Biased ICP sensor/PCM
-Open ICP sensor circuit
-Short to SIG RTN or PWR GND on ICP sensor circuit
-Open in VREF circuit
Possible causes:
I've i selected all my wiring and it all looks good. No chaffing No oil in icp harness. Can it still go bad without leaking oil? If I unplug it when it's running it has no change in idling. Does that mean the pcm is already reading false icp pressure? Only thing different when I un plug it is the SES light is constantly on
