351w build
351w build
i have a 85 f250 with a 351w, i swapped the zf5 in it and it has 4:11 gears and 35's. The motor is all stock, with the 2 barrel carb and stock distributor, ignition, ect. I want to build the motor and i want to go a little crazy with it . I saw the eddlebrock top end kit, and was wondering what you guys think of it and what would be an effective way to build my motor. I'm looking to get about 500-600hp. Any input would help Thanks
on
Wow.. how much you got to spend? That is certainly possible but it's not going to be cheap, I'd suggest you consider buying or copying this.. FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines - FordStrokers "Liberator" Longblocks - :: 408 Complete Longblock
rwrogers
03-03-2014 04:30 PM
steve1980
11-29-2003 09:32 PM
