Holley / Motorcraft 4180c - HELP
I have a 1983 Ford F250 ...... and I am in California so it has all the emissions crap on it .... The stock Holley 4180c took a crap .... beyond rebuild .... there is a crack in the rear meetering block so fuel leaks out and the fuel rail is dented as well. Doubt a typical rebuild could fix this problem.
Any ideas on what I can do to get er running again without spraying fuel everywhere? A rebuilt carb of this type is super expensive ..... Can't find a used one at my local pic n pull either. I would like to pickup a used one somewhere that is in ok running condition .... I can do a standard rebuild to it myself,
So any help would be greatly appreciated,
Thanks
Thanks
About a dozen years ago I got a nicely rebuilt Autolite 4350 from Recarbco from their outlet in Emeryville. Not exactly cheap as I recall, but good.
Also if you are near Sacratomato there is a good Ford truck recycler called Rancho Ford Truck.
Don't know what you call super expensive, but this place has them for $198.
Ford Trucks, Broncos, Rangers (8 Cylinder) 4 Barrel HOLLEY - all - Guaranteed Carburetors
Jim
Jim
cyretired2
07-16-2018 02:01 AM
Tkc432
03-13-2015 08:48 AM
kadrocker
Pennsylvania Chapter
05-16-2009 09:17 AM
HonorableKingCab
01-03-2008 07:15 PM
