HELP!!!
@ OverKill377
I had to use a large screwdriver to pry the IM loose from the IM gasket when I changed the Intake Manifold on my '04 5.4L. I assume you have the water jacket crossover and alternator off - because the IM isn't going to come out of there unless you do.
There are some good photos of the manifold and the CMCV in this link
https://www.ford-trucks.com/forums/1...any-ideas.html
The vacuum line to the power brake booster is attached WAY DOWN on the rear (drivers side) of the manifold [right about the accelerator peddle], and getting it off and back on is the worst! I replaced the whole vacuum line and attached it to the intake manifold port before installing the manifold.
Also, be careful torqueing bolts on reinstall. There are different torque specs for non-plastic manifolds and I twisted one bolt off on mine. I think the correct torque for the plastic manifold is about 9 lbs.
Hope this helps.
Hope this helps.
snortonnorton
01-14-2012 10:35 PM
shortbed1
06-27-2010 09:40 PM
imlowr2
07-16-2004 06:15 PM
