Updated Spy Shots of Super Duty
#122
Torsion bars are a fine way to spring a vehicle. They do not offer much suspension travel, unlike a coil spring, but do well to hold up a heavy weight. I have some friends who have a 2009 Chevy 2500 HD Regular Cab 6.0L. They put a 9' stainless Boss V-plow on it...too much plow for the front of that truck. It works, but it really squats when you pick the plow up. That's even with a Fisher Poly-caster in the bed.
#123
Actually, GM did much to improve the strength of their HD IFS front ends, I believe in 2009. The earlier versions were laughably weak. The tie-rods on them were constantly bending.
Control arm suspension, such as what GM uses, both rides and handles better than a solid axle...reason being, if one wheel hits a bump, that wheel moves but not the other opposite wheel. On a Ford, or RAM, if one wheel hits a bump, it upsets both sides of the vehicle.
Nevertheless, I do not want IFS on an HD truck. It will require more maintenance - ball joints and bushings, and provides lesser ground clearance, and typically wears out tires faster.
#124
#125
This will be the second 6.0L I've owned, and the 4:10 rears really make a nice gas package. Plenty of power to tow a reasonable weight, decent pick up and MPG.
I've got no problem with GM's 6.0 gasser.
Drive a GM 5.3, and I promise you, anything is a significant upgrade.
My wife's 15' Denali has the new 6.2l 8 speed, but they seem to have a different feel. A little more performance on the Denali, and more low end on the 6.0l. Obviously they are geared different, and probably cammed very differently.
The truck has 54 miles on it, and it's already back to the dealer for a couple days because of a bad transmission cooler that greased up my garage floor. That aside, I'm still impressed with the ride for a shorter truck.
#126
#127
#128
Review of the new Ford Super Duty and 18 spy photos here 2017 Ford Super Duty pickups, review, specs, description, photos | Best cars 2016-2017
#129
#130
Our city runs a mixed fleet of big Navistar 4x4 plows and about 10 Ford F-550's with 9' plows and wings. Originally, the city was using DRW F-350's but that plow was sinking the front ends. Now it's just 550's and a few 350 SRW trucks with 8' plows.
#131
#132
Not when the weight of the plow exceeds the max of what the torsion bars can handle even when cranked all the way. It was a really nice plow, but just a bit too big. Really needed to be on something like an F-550.
I simply try to never go anywhere far with the plow on the truck. The Fishers are so easy to install and remove, that it literally takes about 20 seconds.
I did notice the front end with the plow prep package is rated at 6,200 lbs.
GM must have upped their game recently.
#133
some more news about new 2017 Ford Super Duty on
2017 Trucks News - Release Date, Prices and Specs
2017 Ford super duty
Who writes this garbage?
#134
