Updated Spy Shots of Super Duty
#91
#92
As to the 2017 area of the board, I like it and think I'll stay. It it irritates you, all the better...
#93
#94
#95
#96
I'm not sure why anyone would want to get away from a tried and true dana 60, and move to something else. Some of the worst riding trucks I've ever owned were GM ifs trucks. Everyone has different needs and a solid front axle fits my needs. After a couple hundred thousand miles our trucks get used to haul hunters through flooded fields. IFS doesn't work for us for a myriad of reasons.
#97
Right. Everyone has different needs and likes. No truck will fulfill all your likes and needs so you buy the one that has the most in the plus column and the least in the minus. The last time around for me, it was a Ford. Will see what is available the next time around.
As to ride quality, the current version of GM's IFS is the best ride of the big three HD trucks and they've beefed it up quite a bit too. I'm sure Ford could do the same or better if they tried. Hell, Ford is the only one with the nads to build their own diesel and done quite well with it. If you can design a complete diesel from scratch, I'm fairly certain you could build a HD IFS too.
#99
I'm not sure what some are looking at with the GM. It has the exact same 1" archaic torsion bar IFS front suspension it has always had since Christ was an alter boy.
Totally Stone Age and not exactly rough road compliant in any way, shape or form.. If you carry a plow, or load the front end in any way, you better have the tension set exactly the same, of you will be buying tires. It's a proven suspension, but still very archaic 1950s technology. Out of the three, it's probably the worst.
I have both a heavy GM that my company use as a work truck, and an F-350 for my personal truck. Both can not be confused with an Escalade, but the positives of the Ford outweigh the GM because the ride is no better with IFS.
#100
Ford already has IFS , if you want it its called an F150. Buyers who actually need the capabilities of a Superduty truck are going to be less concerned about about an incremental degradation in ride. Like the solid front axle or not, it can't be argued that Ford knows what sells these trucks. Also, I don't think you could find any evidence for Christ being an alter boy, although He did serve.
#101
#103
This wouldn't be reinventing the wheel. If Ford can build a new diesel from scratch, I'm sure this would be in the realm of possibility. I think the obstacle is the preconceived notion that IFS is weak from the days when it was. If the majority of buyers believe it can't be done then they won't buy it even if it is done correctly. It's more of a marketing problem than an engineering one IMHO.
#104
Like I said, I have both side by side, and I drive both daily. I find the Ford actually rides better, but not my much. it does have a longer wheel base, and that's probably the difference.
If you look at what it takes to support a heavy pick up load factor, there isn't much room left for ride compliance. Look at the thickness of the torsion bar GM needs to use to make it work on their heavy trucks.
I just don't understand why this is even a debate.
Don't like it? Buy something else. Ford heavy truck owners want a live axle, hence Ford's continued use and my continued business.
If you drive a short wheelbase, short cab heavy truck, then expect the worst.
If you want a better ride, go with the 172" and the ride difference is big. Better yet, buy an F-150 as suggested above.
