Valve tick won't quit
85 302 with edelbrock alum heads, lifters, and pushrods. I adjusted the preload 3 times and I still have a tick from #4. It's loud enough for me to hear it at idle and gets worse under load. What's next on the list? Pull the pushrods from #4 cylinder and see if one is bent? Can I do that without doing a full top end tear down?
Make sure the pushrod is not binding on something. I had a similar problem on a
small block Chevy engine after putting on a new set of heads. After changing the
pushrod and then the lifter with no improvement we found the clicking pushrod
was rubbing on a hole that was slightly off where it passed thru the cylinder head.
a small grinder shaft fixed the hole and the problem was solved. So much for the
quality control on factory GM heads.
Flat_Ford
09-09-2010 01:14 PM
Reptar360
11-29-2004 06:59 PM
HardFordCore
10-17-2003 09:27 PM
