Help please! My 1950 won't start
Because of an injury I sustained, my 1950 F1 sat unused in my garage for 6 months. I assumed the battery was low so I hooked up the charger and it said the 6 volt was ready to go. Turned the key and pushed the button and all that happened was a rapid clicking sound. Hooked up the charger again, waited and repeated. More clicking. Please tell me that it is just a battery gone bad. Does anyone have any suggestions other than put in a new battery? Thanks
If your older battery was exposed to elevated temps - like say Florida during the summer - the chemistry may be destroyed. Cold weather will expose weaknesses but heat will kill batteries. Get yours tested, replace if needed, and shine up all the battery and starter connections. Let us know what you find.
Clicking usually means there is a current / power related issue. If you get a new battery and it still is doing the clicking, I would check your ground. I had a smilier issue where my starter would just click. I thought I needed to purchase a new starter and it ended up just being that I didn't have the starter grounded correctly. (Note that mine was on a 1967. I do not know anything about pre-1967 trucks, but I would assume it is slightly similar.) What needed up happening with mine was the ground wire got cut some how and was touching where it shouldn't have been. Wrapped the area with electrical tape and never had the issue ever again.
Either way, hope your issue gets resolved.
Received 4,132 Likes
on
Sometimes my starter locks up on the ring gear. When I hit the start button it just clicks. Put it in third with turned off and rock the truck a little. That should free it if it is stuck. I have went through batteries, solenoids, starter pull, etc, all to find out sometimes the bendix hangs when it hasn't run in a while. Try it before you tear it down.
I had this problem with the 226 in my 51. It was the cam gear. It is made of fiber and is directly engaged with the crank gear. A couple of teeth were worn. It didn't happen every time but got worse over time. It finally gave out going down the highway. I was able to replace it with the engine in the truck.
