Noisy front leaf springs - brand new ATS
Been chasing this for a few weeks and getting fed up. Have a bad metal on metal "creaking" noise from the front at low speeds.
Background - Replaced springs with X code front and modded C code rear from Junior at ATS. Also replaced shocks at the same time. All hardware tightened with weight on suspension. Have rechecked torque on ubolts many times, even loosened and retightened both ends of the shackles, sway bar links, shocks, etc.
Can't get the noise to go away. Hard to pinpoint exactly where it's coming from but you can "feel" the noise in the back half of the front springs.
Any help appreciated...
Give us a call tomorrow. We open at 8:30 and leave at 6:00 EST.
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
www.ATSsprings.com
Mine creaked really bad, more so after a,new,front sway bar and then oem used X codes.
It was the fact that where the hellwig sway end links that fit the frame mount are a sloppy fit. The bolt that bolts the bushing to the frame mount is tight to the link bushing but loose in the frame mount. It was really bad.
I pulled them off, greased the crap out of all of it and tightened the hell out of them. Creaking went away.
Not if, but when it comes back I will weld the bolt to the mount so it can't rattle in it.
Still fighting this, driving me nuts!
I have spoken with ATS and they have been more than helpful but are out of ideas. I have greased bolts, loosened and retightened everything I can at this point.
The noise can be "felt" in the rear portion of the driver front spring between the U-bolts and the rear shackle. It feels like the spring steel itself is causing it but I just don't think that's it.
Anyone else have ideas??
May sound silly, but have you tried greasing the springs themselves? I helped a buddy chase down some spring creaks a while back and greasing the leaves quieted it down.
We drove a wedge between the leaves to open up the gap a little then spooned a little grease on the areas that contact each other in normal operation. Don't trust the wedges and use a screwdriver or something to go between the leaves not your fingers!
Good luck!
Good luck!
If all fails, it may be that during your istallation you twisted the frame/body enough that your body mount at same location your describing may have loosened up.
Thanks for all the ideas, it is time to start disconnecting items and then test driving. I do have a front swaybar and I have loosened and retightened all the bolts. The links were replaced just before I bought the truck. Links are not touching the frame.
I did notice the front springs look to have only a piece of thin sheet metal between the two leaves at the center pin. With the u bolts tight I would think it would be OK but maybe not. There are isolators at the ends and the springs don't touch. I also opened up the clamp at the rear to eliminate potential rubbing there.
At this point I'm willing to try anything....
