Back firing through intake then engine dies
The truck starts up fine. then after a minute or so it starts to spit and sputter and back fire through the intake then dies.
What could cause this? Intake manifold gasket leak?
Will a clogged fuel filter cause this?
Any thoughts?
Thanks in advance.
5.4
Any thoughts?
Thanks in advance.
5.4
on
I would start with the fuel filter....
I'm not familiar with the injector configuration on your engine. If there is a cold/start injector, it could be possible that you have a vacuum leak somewhere and the cold start injector is covering up that leak for a few moments when you start it.
Another may be an issue with the IAC motor...
Yet another may be the start/run circuit on the electric fuel pump... This overrides an oil pressure switch for making the electric fuel pump run when there is no oil pressure..
Still - cheaper and easier to do a maintenance on the fuel filter in my opinion.
How many miles are on the engine? Has it been scanned for codes? Was anything recently done to this engine?
A backfire through the intake generally (but not always) means that your ignition is firing while an intake valve is open. There can be many causes of this, some simple, some very expensive. A stuck or poorly sealing intake valve, timing chain, crankshaft position sensor or head gasket failure come to mind as a cause, but there are others.
Start with getting the truck scanned for error codes.
on
Ok let me tell you what I have done.
When the engine starts to die i sprayed engine starter in the intake and it returns to idle. If you give it gas it sputters. Sounds like a lack of fuel? Its too cold and too much snow to replace the fuel filter right now.
What do you think?
What do you think?
The fuel filter is the first thing to replace and from the sound of it, the most likely candidate.
on
Yeah, it sounds like you have a tank full of crud / water... Best thing I can advise is to get it as empty as possible by siphon first.. Then it's just a matter of getting a big floor jack under it and removing the straps and filler neck. When you drop it down a little ways you should be able to get at the wiring harness on top to disconnect.. That's when I take the fuel and vent lines off as well.. You will probably need the special disconnect tool for the fuel line. Not sure on your year truck as I never had to do it on my 99...
