Oil Cooler Orings
Old 03-02-2015, 05:20 PM
bass-n-fire's Avatar
bass-n-fire
bass-n-fire is offline
Oil Cooler Orings
I just received my Orings and gaskets from RiffRaff. In the kit there are 2 sets of Orings, one set black and one set green. When I removed my oil cooler, there are only one set of Orings on it, black. Am I missing something, or is my oil cooler missing something (extra set of Orings)?
Old 03-02-2015, 06:03 PM
lemonshindig's Avatar
lemonshindig
lemonshindig is offline
Old 03-02-2015, 10:43 PM
lemonshindig
Old 03-03-2015, 05:51 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
The small o-rings are probably stuck inside the cooler header/ends. They usually slide off when you pull the cooler out and stay in there.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 03-03-2015, 01:49 PM
bass-n-fire
Well, had a buddy use his press to press the ends back on. I'm standing there watching and before he even puts much pressure, the filter end splits in half.
Things just keep getting better.
Old 03-03-2015, 04:41 PM
williameub's Avatar
williameub
williameub is offline
Been there... Done that...
Key is to make sure those ends are completely straight going onto the cooler. I found that a rubber mallet and a close eye helps with making sure that they are level.
I thinking I've got an extra filter end too, if you need one.
Old 03-03-2015, 06:12 PM
bass-n-fire
I guess I am just not patient enough. Already purchased a new one from Tousley Ford, I think. Thank you though.
Old 03-03-2015, 06:54 PM
williameub's Avatar
williameub
Ouch! I know what those things go for!
Goodluck on the next one!
Old 03-03-2015, 07:49 PM
bass-n-fire
I'll definitely a lot more careful and observant on the next one.
Old 03-04-2015, 09:23 AM
bass-n-fire
Just so I don't have to order another end, is it easier to do one end at a time as opposed to trying to do both at the same time? I'm thinking this is where I went wrong and created more work for myself and more expense.
Old 03-04-2015, 11:19 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
No, do them together.
I just saw a pic online someone used a small ratchet strap and pulled them onto the cooler.
Think I'll try that next time.
__________________
Old 03-06-2015, 07:17 AM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
If you super lube up the o-rings and cooler ends they go in by hand very easy. It also prevents the o-rings from rolling.
Old 03-07-2015, 06:53 PM
bass-n-fire
Thanks for the replies. As soon as the new part arrives, I'll give it a shot.
Old 03-07-2015, 07:39 PM
Krause's Avatar
Krause
Krause is offline
https://www.ford-trucks.com/forums/1...thread-11.html
Post number 157, after a bunch of other pictures.
Ratchet strap and vaseline.
-Andrew
Old 03-07-2015, 08:45 PM
bass-n-fire
Thanks for the link Andrew. I have to say that Engine looks sweet. Wish I had the time and money to pull mine and go through all that. Just not in the cards right now.
Quick Reply: Oil Cooler Orings
