Re-seal the whole valley
I have known leaks at the fuel bowl and turbo. My truck has 370k or more on it. I'd like to replace every oil, fuel, and turbo o-ring as well as all hoses while I'm in there. I don't want to spend the few hundred extra for E-fuel.
Do you see anything missing from my shopping list? I don't know if my dipstick is leaking or not; I'll have to check. I don't have any problem with my oil cooler but I figured I'd rebuild it anyway. My stock air box is broken so I might as well do the 6637, but I'm not crazy about the kit that costs $100 when the filter itself is about $35. Suggestions?
Thanks
-Matt
<table class="CartContents Stylize General" cellpadding="0" cellspacing="0"><tbody><tr class="First Odd Even"><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> CCV Vent Cover Orings
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d6fc7c034]" id="text_qty_54f3d6fc7c034" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $4.50 </td><td class="CartItemTotalPrice Odd" align="right">$4.50</td></tr><tr><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Oil Rail Plug O-ring Kit
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d7710da9a]" id="text_qty_54f3d7710da9a" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $3.50 </td><td class="CartItemTotalPrice Even" align="right">$3.50</td></tr><tr class="Odd Even"><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Oil Rail Drain Plug O-rings 94-03
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d7a4a8997]" id="text_qty_54f3d7a4a8997" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $3.50 </td><td class="CartItemTotalPrice Odd" align="right">$3.50</td></tr><tr><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Oil Fill Riser To Valve Cover O-ring 94-03
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d7f0da54e]" id="text_qty_54f3d7f0da54e" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $1.60 </td><td class="CartItemTotalPrice Even" align="right">$1.60</td></tr><tr class="Odd Even"><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Oil Level Gauge - Oil Pan Repair Kit
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d890de041]" id="text_qty_54f3d890de041" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $49.94 </td><td class="CartItemTotalPrice Odd" align="right">$49.94</td></tr><tr><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Oil Cooler Seal Kit
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d8ae4806d]" id="text_qty_54f3d8ae4806d" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $69.95 </td><td class="CartItemTotalPrice Even" align="right">$69.95</td></tr><tr class="Odd Even"><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Complete OBS Fuel Bowl Reseal Kit <table class="productAttributes" cellpadding="0" cellspacing="2"><tbody><tr class="First Last"><td class="Odd Even"> <label>Type of Drain Valve O-rings:</label> </td><td class="Odd Even"> Viton Drain Valve Orings </td> </tr> </tbody></table> Change
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d927ec33f]" id="text_qty_54f3d927ec33f" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $12.50 </td><td class="CartItemTotalPrice Odd" align="right">$12.50</td></tr><tr class="Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Fuel Bowl Regulator Bypass Hose 1994-1995
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d953bd88c]" id="text_qty_54f3d953bd88c" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $9.92 </td><td class="CartItemTotalPrice Even" align="right">$9.92</td></tr><tr><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Fuel Pump Hoses
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d96144263]" id="text_qty_54f3d96144263" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $5.55 </td><td class="CartItemTotalPrice Odd" align="right">$5.55</td></tr><tr class="Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Fuel Pump Upper Hose
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d96aad80e]" id="text_qty_54f3d96aad80e" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $3.67 </td><td class="CartItemTotalPrice Even" align="right">$3.67</td></tr><tr><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Parker 60VLV-4 Viton Sleeve (1/4 inch)
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d99371f8b]" id="text_qty_54f3d99371f8b" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $5.20 </td><td class="CartItemTotalPrice Odd" align="right">$5.20</td></tr><tr class="Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Tank Return / Fuel Drain Valve Connecting Hose
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3d9b4acd57]" id="text_qty_54f3d9b4acd57" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $5.24 </td><td class="CartItemTotalPrice Even" align="right">$5.24</td></tr><tr><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Turbo / Pedestal O-rings
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3d9f43b844]" id="text_qty_54f3d9f43b844" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $6.00 </td><td class="CartItemTotalPrice Odd" align="right">$6.00</td></tr><tr class="Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> IPR O-ring Repair Kit
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3dada748a3]" id="text_qty_54f3dada748a3" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $11.89 </td><td class="CartItemTotalPrice Even" align="right">$11.89</td></tr><tr><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Pressure Port/ HPOP Reservoir Fill Plug
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3db2d8bea6]" id="text_qty_54f3db2d8bea6" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $2.90 </td><td class="CartItemTotalPrice Odd" align="right">$2.90</td></tr><tr class="Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Garrett Compressor Housing O-ring 94.5-Early 99
</td><td class="CartItemQuantity Even" align="center"> <input size="2" name="qty[54f3db3abb293]" id="text_qty_54f3db3abb293" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Odd" align="center"> $5.19
</td><td class="CartItemTotalPrice Even" align="right">$5.19</td></tr><tr><td class="CartThumb Odd" style=""> </td><td class="ProductName Even" colspan="1"> Garrett Compressor Housing Outlet O-ring 94.5-Early 99
</td><td class="CartItemQuantity Odd" align="center"> <input size="2" name="qty[54f3db5982da7]" id="text_qty_54f3db5982da7" class="qtyInput quantityInput" value="1" type="text">
</td><td class="CartItemIndividualPrice Even" align="center"> $3.29 </td><td class="CartItemTotalPrice Odd" align="right">$3.29</td></tr><tr class="Last Odd Even"><td class="CartThumb Even" style=""> </td><td class="ProductName Odd" colspan="1"> Riffraff Diesel 6637 Filter Kit <table class="productAttributes" cellpadding="0" cellspacing="2"><tbody><tr class="First"><td class="Odd Even"> <label>Cover Color:</label> </td><td class="Odd Even"> Blue </td> </tr> <tr class="Odd Even"><td class="Odd Even"> <label>Vehicle Year:</label> </td><td class="Odd Even"> 94- Early 99 +$12 </td> </tr> <tr class="Last"><td class="Odd Even"> <label>Filter Type:</label> </td><td class="Odd Even"> 6637 Filter </td> </tr> </tbody></table> Change </td></tr></tbody></table>
Thanks
-Matt
