4bbl Intake C1AE3425B
Aftenoon list.
I have a chance to purchase a FORD 4 BBL intkae for an FE. It is cast iron and has the casting number C1AE3425B
Anyone know the factory application, and as factory intakes go are some better than others?
I assume there would be no issues with using it on a 1972 360?
That would be a 1961 unit off a 352? 390's were out in 63 I think. There's no real problem running it on your motor unless your finicky about everything matching perfectly since the intake ports will be taller than the ones on the newer style heads. It''ll have the draft stuff on it, no pcv back then.
kilich
11-27-2011 08:54 PM
gliderdad
03-27-2009 11:40 PM
rsalter66
12-18-2007 06:49 AM
mechanically retarded
10-09-2003 12:34 AM
