Installed DieselSite WS and Filter System
I installed DeiselSite WS and Filter systems on my trucks today. They are expensive but I hope its worth it for the insurance of never being told by FORD that I have rust or crap from fuel in my injection system that caused the failure and my warranty is void. I definitely can't afford that fix it ticket. I will post some pics later and I am going to keep track of the OEM filters at the scheduled changes to see if they look better than they have in the past. I changed the 2015 filters today at 5K miles,since I was already covered with DF, and they were quite soiled for only 5k miles.
I don't see how they could blame anything on this unit because it is pre OEM filters. This filters the crappy fuel we buy before it even gets to the OEM filters. With this system installed there is a total of four filters before the fuel gets to the injection system. The folks at Dieselsite have researched the FORD filtration system and found that it just doesn't work as good as it should. IMO it seems like FORD should have a better OEM system in place since the quality of diesel fuel is so bad and their fuel system is so delicate.
Thanks. At this point I can say that the installation is easy as pie and can be done in about 20 minutes. Everything about the unit is very accessible and the clear bowls will allow me to monitor what is going on without removing the filters. The replacement filters are about $10 each so it will be an additional $20 when I replace all four filters at 10K intervals.
How do you like the AD II? Do you have to use AD filters specifically? I went with this unit because of the ease of the install, the clear bowls, the replacement filters are very common and I was able to get a discount for buying two units. I did not get the heater. Not only are they are proud of that thing I didn't think I needed it here in FL. We get some freezing weather in north FL but it is very seldom. I couldn't bring myself to justify the cost.
I agree. It is pricey but it appears that they did their homework and used quality materials and did a great job of fabricating the unit. Have you done a OEM filter change since you have had the DS filtration system installed? Any differences that you have noticed? I am hoping it was money well spent. It definitely can't do anything less than help keep more water and trash out of the fuel system.
I've had this setup for about 30K miles now. Very happy with it. One thing I've noticed is that the filter minder on the Dieselsite setup shows just under half restricted after about 7K miles. I am under there draining the bowls, and noticed this. So, I have gotten in the habit of replacing the dieselsite filters at every oil change, and the OEM ones every other oil change.
I have never observed any water in any of the bowls.
I've had mine on for about 12,000 miles and have had no issues. My minder is still only at about 1/4, but I will change the filters in about another 3k. I like being able to see the fuel quality by just squatting down next to the truck, rather than having to crawl under to drain to check. (I still drain, but with the clear bowls, you don't have to drain to see the water.) As much as we spend on accessories for these things to make them look better, I felt the high price was worth the extra protection and peace of mind.
Dieselsite stands behind their claim that their system will in no way change the fuel flow or place any additional loads on the pump.
