P0420 Catalyst below threshold bank 1
Old 03-21-2016, 05:04 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
Originally Posted by F150Torqued
WOW!!!! I sure hope you don't ever encounter a small crack in your plastic intake manifold - or a sticky fuel injector that decides to 'occasionally' stick closed, and then 'occasionally' decide to stick partially open or close too slowly, or a mass air flow sensor that's temperature sensitive and don't work right only in cold temperature ---- or about a thousand other off the wall failures. You'll go broke replacing O2 Sensors and CATS because they have their own respective codes for lean / rich and catalyst efficiency low.
THe exhaust manifold was cracked. and the manifold and cat was one piece......(This is on a Honda civic..which Im still driving) if the plastic manifold had a crack in it, it would have a vacuum leak or a water leak........on my 2001 F150, it was a water leak.....it got replaced too
Old 08-02-2017, 04:06 PM
ITDave's Avatar
ITDave
ITDave is offline
How much did the replacements cost you parts and install?
Thank you!
Originally Posted by JJed
I was getting the same code. Swapped out the factory cats for high flows and waalaa codes were gone and the truck sounded better!! :-)
Old 08-10-2017, 06:36 PM
mikeyb132's Avatar
mikeyb132
mikeyb132 is offline
A P420 code is telling you to replace the cat soon. VERY soon. I bought my truck (used), and within 8 months I had to take the truck in to have it fixed. Long story short, the cat was plugged and needed replacement. AND to top it all off, in California you HAVE to buy factory, because no aftermarket cats are CARB approved.
Old 08-10-2017, 09:04 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Originally Posted by mikeyb132
A P420 code is telling you to replace the cat soon. VERY soon. I bought my truck (used), and within 8 months I had to take the truck in to have it fixed. Long story short, the cat was plugged and needed replacement. ....
Not at all. The DTC means the cat isn't working, that's it. It does NOT mean in any way that that cat is or will be plugged.
Old 05-13-2019, 08:07 AM
66F100Again's Avatar
66F100Again
66F100Again is offline
On my 2004 5.4 with 130k, code P0420 bank 1 went away after I fixed the exhaust leak that was downstream from the catalytic converter and downstream from the y-pipe at the factory clamp. I also had, and still have, slight exhaust leak at the exhaust manifold on passenger side like most 5.4's have (warped flange?). Seems odd the code went away after fixing exhaust pipe leak, but maybe it was due to restoring back-pressure? Any other theories as to why this worked? Anyway, thought I'd post this in case it helps anyone.
housedad
02-15-2014 01:22 AM
bla1879
Exhaust Systems
03-20-2011 12:05 AM
caseys
12-12-2007 11:35 AM
tradosaurus
02-26-2007 08:56 AM
tom_strandberg
3.8 & 4.2L V6
09-18-2005 02:02 PM
Quick Reply: P0420 Catalyst below threshold bank 1
