'04 6.0L cold start, long crank problems
@cheezit
Early '04 6.0L, long crank on cold start, started happening about 4 months ago. Just in time to make our trip to Tahoe less than exciting...
Video:
https://www.dropbox.com/s/4sauykz3rg...84338.mp4?dl=0
New 6-phase BulletProofDiesel FICM
New Injectors
New Turbo
BANKS tuner bypassed so completely stock tune
ECU & FICM flashed 2 months ago with most current OEM tune (that sucks *** but eliminates the EBP sensor which was failing... again...).
Looks like it's taking too long to build pressure which makes me think it's definitely an HPOP imminent failure...
Thoughts?
Video:
New Injectors
New Turbo
Thoughts?
Give me until Tuesday and I'll let you know everything I did. I'm doing another oil cooler for sure since mine has 60k since being changed, a new turbo drain pipe, new ipr but that may be included with the hpop, new t-stat, new oil pressure switch, blue spring upgrade on the fuel pump, complete coolant flush, new oil and filter, and I think that's it.
Mine is a late '04 so there are some differences. Also, it's probably going to cost me a lot more because I'm going with all new Ford parts and doing the oil cooler again. He said about $3300 total. I hope that's including the tow, but probably not. I hope this is the last trip to the shop for quite some time. Once this is done, I have replaced and repaired ALL the stuff that is supposed to be problematic with the 6.0. No matter how much it is , it won't add up to more than about 5 or 6 payments on a new truck, at least that's what I keep telling myself.
If I didn't have my 5th wheel I wouldn't be putting another penny into this truck. I would let it sit in the driveway until I could sell it for what I could get for it. But then I would still have to spend money on something else to drive. An F150 as nice as my 350 would probably cost more that the 350 is worth. It's really a no win situation once you get into one of these things. Plus when I get it back I still have to put on new rear shocks, sway bar end links, and I wanted an in-dash radio with nav, but that's out now.
Someone with more knowledge than me will probably add to this or correct me. If you have gauges, you should see at least 500psi on the hpop to start the truck, then the psi should increase as the throttle increases. You should also have a % in the ipr gauge. That should read around 24% at idle. If it is going to 84ish then the hpop isn't working?? Mine died with no warning and would only start and idle. It would not rev up like yours.
Update: Got her back tonight
Mine was finished yesterday but when he test drove it he found the oil filter housing leaking so that was fixed today and I picked it up. Here's what I ended up with. Ford HPOP, Ford oil cooler, new oil filter cap, t-stat, oil pressure switch, intake gaskets, updated turbo drain tube, fuel pressure reg. upgrade kit (blue spring?), IPR valve, EGR cooler o-ring kit, HPOP branch tube, oil filter housing, rear Racho shocks. Along with all that we changed to Rotella 15W-40 and Rotella ELC coolant. I didn't have the gauges with me but he said on the shake down my oil was within 2 degrees of the coolant.
RobMF250
07-20-2018 08:20 AM
EricdeToad
02-24-2015 09:27 PM
cope1972
11-29-2014 07:33 PM
