Help: Fuel in my coolent ford says blown head gasket
update
Talked to ford this morning with a heavy heart. I have a hole in my head. I am told we can't replace 1 because pressure will be diffrent? So only option is a remanufactured engine for roughly 14,000 I'm told.or both heads for 8,000 with no surety something else in the engine will not fail. I love my 6.0 know what? Maybe buy a new truck. Any suggestions on the most reliable ford diesel for towing my construction trailers with a lot of mileage as I travel all over the east coast remodeling Rite Aid pharmacy's
Our heads are machined flat (or what Ford likes to call flat) so can someone explain to me how replacing 1 head would cause any difference in cylinder pressure (or any other pressure for that matter)?? I agree that it would be deemed good practice to look at the other cylinder head but would it not be cost effective/worth while to send his good (as far as we know) cylinder head to a machine shop for a once over, get new guides, and trued up? Of coarse I understand that he is at a dealer so they are following a Ford recommended guide on steps to take, but I'm just talking real world senario for a sec.
Valve sealing would be my guess. But without the dome in
the chamber I also don't see how. That being said do a top
side rebuild and new rubber for the cooling system and you
should be good. Might think about studs while your in that far.
If you go with Ford heads give Ed at FICM Repair a yell for pricing.
You very likely will get a nice surprise over the Ford price.
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
Sean
Sean
I think I may be the first poster to post a picture of a post in a post
I don't think it would be a pressure issue. If his truck has the pre-commonized heads it may explain why they want to do both. I think only the commonized variety are available and there were many changes. You probably wouldn't want to mix on the same engine. There was some info on mixing them in another ford document but I can't find it right now. It does seem to imply it's ok in this document.
Talk about a Frankenstein's Monster. All types of odd parts.
Sean
I've seen burnt valves with holes in them, cracks n stuff in different places but anybody ever seen damage you would describe as a "hole"? I'm having a hard time visualizing that.
I know it's shaping up to be an expensive repair but if it were me I wouldn't walk away unless the rest of the truck is used up.
I don't see an issue replacing one head and see absolutely NO reason for a complete motor or short block unless some internal damage has been done that's not readily evident.
There is no freakin way that fuel in the coolant is just cause for a long block!!! With all due respect,, if you are gonna come on here,, at least give us a chance. I would be dragging my truck as far from that dealer as humanly possible. What dealership is it???
It's your truck and you do what you want,, but don't be a 6.0 basher in the future because you listened to a service advisor over the help here. I understand that most people feel that the only trusted place to take you truck to is a dealer,, AND THERE ARE GREAT DEALERS OUT THERE,,,, BUT THIS ONE IS NOT ONE OF THEM!!!!!
Hate it when someone is posting in real time about how they are getting robbed.
I've done many of these failures and replacing one head is an option,,, sending the other off to match recession and a valve grind and seals.
After reading this I'm half tempted to load up the BPD kit and roll out there and fix this truck in the parking lot just to shut that service advisor up!!!! Has anyone else out there bought the cracked head repair tool???
A crack is MUCH DIFFERENT than a "hole". Lol
got my truck back
Well I got the truck back they told me it won't last long.I took your advice and I am going to find a good diesel shop to bring it to. I will be buying a new 6.7 f250 for the new work. Can't take a chance of breaking down while business is good. When I get an accurate diagnosis of what's wrong with it and a fair price I will get the work done. It's a good truck everything else is working great plus a have put 12,000 bucks into it over the last year.
