I am in need of a new steering column for my truck due to bad bearings tearing up the old one. I found one in a local salvage yard on a F150 with an airbag. Are the columns the same in the 150s except for the steering wheel? What about the wiring for horn and cruise control?
Thank you.
Yes the columns in the F150s are the same. Use your steering wheel and swap all the wiring and parts from yours over to the new one and you will be good to go.
