2001 f150 5.4 help me im stumped
hey, I have a 2001 f150 5.4L v8
On cold mornings (under 45 degrees or so) my truck has a bouncy idle when stopped at a light or stop sign. it starts fine and once it warms up it runs fine. It is throwing po171 and po174 codes and I have replaced old hoses and do not believe it to be a vacuum leak. I have not done anything with the maf, but that is my next step once i get time to do so. I have looked up videos and forums and anything i could find on the subject and thats all I can find. anything else anyone can think of that it might be would be greatly appreciated.
"hoping for the best" will be one huge waste of time and money---unless you have plenty of both have those leaks diagnosed first.
If you've checked and are 100% certain the PCV plumbing running to the back bottom of the throttle body is intact then begin checking for leaks with the "spray method". Videos of this process can probably also be found online, search for something like "finding engine vacuum leaks...." or something similar. (That phrase should be generic enough to get a lot of results---wade through them for the one that suits you.
is there a way to check that before I tear all that apart,
Simply spraying and listening rarely works unless you have a severe leak that is causing a pronounced impairment of idle quality (loping, stumbling, etc).
My 2007 f150 every now and again gets rough idle and eventually kicks itself into limp mode. I found that my throttle body gets a bit dirty along with maf. I just pull it apart clean it well with cleaners and put it back together. Works good for a few years. Might be worth something checking out.
Stacy Lynn
1997-2006 Expedition & Navigator
03-07-2018 02:52 PM
airpilikia
2004 - 2008 F150
01-09-2013 04:20 PM
