best (cheapest) way to go from Non-limited Slip
best (cheapest) way to go from Non-limited Slip to LS rearend..
got to checking my door label and under AX i see 31.. which tells me i have a 3.73 non-limited slip rearend.
So what is best way to change over to LS.. i have read about getting one at local salvage yard but not sure how that might work not knowing the history of the unit, ie miles, frequency of fluid changes, etc..
I see the summit racing locker is like 600 bucks so that might be out.
need help in trying to figure this out..
EDIT: happen to find this at 4wheelparts.com looks interesting and there is one in my town.. http://tinyurl.com/kcqsv8p any input on this model..??
While I do not have a LSD, the best reviews from people I have talked with is the "TRUETRACK". The LOCKER is a different design all together.
However, Many prefer the a "Locker" in the front housing and for off-roading.
The thing about an OEM LSD is it will only engage the clutch pack at about 15 - 20 MPH and 1,500 RPM.
Maybe the trutrack is more helpful on snow and ice or something, but I imagine most who need that on a regular basis have a 4x4.
I debated about rebuilding my LSD, but then decided by the time I have to rebuild it again,
I would have paid for a Tru-Trac. I LOVE my Tru-Trac. My truck hasnt been in 4 wheel drive since I had it installed. That includes climbing muddy mountains in Colorado. I think I was in the area of $700 with install.
My LS in my truck is mostly slip but on the fence as to install a locker as i go hunting alot in the cold and she goes pretty good in 4wd as it is. In 2wd drive it is bunk. the combination of huge torque and no wt on the rear makes spinouts a regular occurance. Gotten real good at feathering the go pedal in those times.
If you have never driven one go in a truck that has one and see what you think.
The factory limited slip (or any clutch type of differential resistance mechanism) gives zero ****s about vehicle speed or RPM. The Gov-loc "G80" rear differential is able to sense (thanks to centrifugal force) a wheel speed differential and physically lock the two axle shafts together but this isn't a GM truck forum.
If friction were infinite, the clutches would never allow slippage to occur between the differential carrier and side gears. Two things determine the effectiveness of the limited slip differential: clutch preload and torque differential between each axle shaft (all provided that there is actually friction material left on the plates). The reason that the limited slip action deteriorates over time can be found mixed with the metal powder on the fill plug magnet. The really neat thing about the effects of torque on differential side and spider gears is that the higher the torque load, the more outward pressure the spider gears exert on the side gears - actually INCREASING the clutch pressure holding the side gears to the differential case.
If the statement about speed and RPM were true in the case of our Sterling 10.5" rear ends, I guess I have a unicorn that doesn't adhere to those standards.
Another interesting thread with great information. My father used to have GM pickups with 'locking' differentials. It seemed like they locked together after about 1 revolution of one wheel spinning and the other not. The only thing I didn't like about those was that the one wheel had to dig you in a little deeper before the other one kicked in.
Go feed your Unicorn. You have to have centrifugal force on one wheel to engage the clutches to make friction. If it were a GM Thread, you'd be worthless there as well.
so now i am confused.. What is the main difference between a locker and limited slip.. I was trying to get to what is OEM install in the diff from factory known as Limited slip.
I understand the locker is better and a bear on ice,, which i plan NOT to be on, but how about just around town with turns and such.. I was wanting something that will be mostly normal driving around town and have better footing when it get a bit slippy out.
edit
i found this at 4 wheelparts and see it a limited slip.. which way to go..?? http://tinyurl.com/nmbw83j
edit
I have had 3 lockers ( Detroit) in different vehicles over the years. My experience has shown me that in the snow and ice they are a hand full in 2wd if that is what you have. If you have a four wheel drive and it is IN four wheel drive they are awesome. Just point where you wanted to go. It was an adventure when you hit a icy situation in 2wd as the whole rear end would just break loose, but you need to be prepared for those situations.
Typically a locker is selectable, so it's an open diff unless you say otherwise. A detroit locker is a bit different. Trutrac is a limited slip set up. Ford's OEM limited slip is mostly just limited in what it can do in my opinion, even when you change out the fluid and don't overdo it on the additive.
Here's a link that may offer some additional info for you.
Differentials and Traction Control
