1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Removing bed bolts
Old 02-22-2015, 06:17 PM
Built_Ford_Tough_757's Avatar
Built_Ford_Tough_757 is offline
Removing bed bolts
Need to remove my bed to install a utility body next week. I tried to loosen the bed bolts, broke 2 torx bits. My question is, can I just grind the bolt head off? get the bed off, then grind whats left of the bolt?
The reason i ask is because I tried this on my 1985 and the bolts were oddly shaped.
Old 02-22-2015, 07:16 PM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
Use some penetrating oil on them. I've never he an issue getting them out. If you have a bolt extractor/remover you could cut the heads off then remove what's left once bed is off. Might take some heat depending.
Old 02-22-2015, 07:36 PM
dkf's Avatar
dkf
dkf is offline
I had to grind the heads off two of the bed bolts on my 04'. The bolts seize fast to the captured nut clips that are on the frame. I used an angle grinder with a flap abrasive wheel and slowly worked it down trying to avoid digging into the bed itself. Worked pretty good. Once the head was off you can lift the bed straight up.
Old 02-22-2015, 09:27 PM
02F250SCSD4x4Dgo's Avatar
02F250SCSD4x4Dgo
02F250SCSD4x4Dgo is offline
I had to use cutting torch on my 02 also need to get a torx plus it fits the head beter and wont break as easy.
Old 02-23-2015, 07:35 AM
DavidB's Avatar
DavidB
DavidB is offline
You might also want to try a Torx + bit since they are Torx + bolts. Torx + bits and bolts are a LOT better than standard Torx. Torx bits will sometimes work with Torx + bolts, but it is NOT a good fit and can easily break the bit if the bolt is tight.
You might want to double check for the size, but I believe that this is it:
Amazon.com: OTC (6188) TORX PLUS Socket - TP45, 3/8" Square Drive: Automotive Amazon.com: OTC (6188) TORX PLUS Socket - TP45, 3/8" Square Drive: Automotive
Alternately, here is a set:
Amazon.com: OTC (6180) TORX PLUS Socket Set - 9 Piece: Automotive Amazon.com: OTC (6180) TORX PLUS Socket Set - 9 Piece: Automotive
http://www.acument.com/products/comparison/
Old 02-23-2015, 08:21 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Use some impact torx bits. They come mounted to the female reciever for your impact driver. ditto on the use of penetrant.
Old 02-23-2015, 10:36 AM
02F250SCSD4x4Dgo
it is a Torx+ 50 i am almost positive i bought one off of amazon but cant check my order right now. it was almost 9 bucks.
Old 02-23-2015, 11:10 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
If you live in a salt zone forget about penetrating oil etc. ive removed four Ford beds ranging from 2000-2009 and no amount of PB Blaster, fluid film etc helped. Broke countless torx + bits and finally just removed the gas tanks and torched the bolts off. If your good with a torch you wont do any type of damage to the truck frame
iPhone from IB AutoGroup
Old 02-23-2015, 11:32 AM
dkf's Avatar
dkf
dkf is offline
Penetrating oil did not really do much on mine and like I said I still had to cut the heads off two. Over the course of a week they got drenched with penetrating oil half a dozen times or more. I even tried some heat on the stuck ones. After breaking half a dozen torx bits grinder came out.
The Torx bit size is too small and the bolts form the threads which gall easy and then they rust fast. Another bad design just to facilitate quick assembly at the plant.
Old 02-23-2015, 11:39 AM
dr1's Avatar
dr1
dr1 is offline
Gave one a turn for laughs, then chopped all 8 heads off.
Old 02-23-2015, 04:20 PM
badlar's Avatar
badlar
badlar is offline
On my 01 a few years ago, I took a 1" nut, scribed the shape onto the bolt head, zip disk in grinder to cut the head the shape of the 1" nut, 1" impact socket on ratchet with a 4 foot snipe, all 8 out with LOTS of effort, didn't break a single one!
Old 02-23-2015, 08:51 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Why not just torch them off from under the truck?
Sent from my Telegraph using IB AutoGroup
Old 02-24-2015, 10:12 AM
badlar's Avatar
badlar
badlar is offline
Thats an easy one, I don't have a torch!
Also, In my case the bed was going back on, so I wanted to reuse the hardware.
Old 02-24-2015, 10:26 AM
xmontex4's Avatar
xmontex4
xmontex4 is offline
I didn't even consider trying i just broke out the grinder, its faster IMO if you live up north to cut them and install new ones and potentially cheaper if you end up breaking a few bits and then have to buy a few bolts to replace the stuck ones. After looking i may have been able to get 2 out of the 8 out in the end and new bolts off Ebay are $40 sometimes.
Old 02-24-2015, 05:55 PM
Lou Braun's Avatar
Lou Braun
Lou Braun is offline
Last year I was able to remove 2 bed bolts with penetrating oil and an impact. The rest were cut off with a standard plasma cutter.
These bolts were soaked with penetrating oil for several days before attempting to remove them. The stuff that they put on the roads now should be patented for its ability to weld steel parts together.
Lou Braun
Quick Reply: Removing bed bolts
