boost
Boost parts
Manifold
Pipes
Cooler
Blow off valve
Wideband o2
Tuner
Gauges
Injectors
oil lines
Pistons
Rods
Rings
You can only run 5-8 psi on stock internals without detonation and cracking the cast pistons.
It's been a while since you posted this, if you have gotten it on already how is it?
Pipes
Cooler
Blow off valve
Wideband o2
Tuner
Gauges
Injectors
oil lines
Pistons
Rods
Rings
therifleman556
41
04-05-2009 10:55 PM
f350rebel
07-01-2007 08:49 PM
