1949 F-1 Seat bolts
The parts book I have shows the bolts for the 53/ so I can't answer your question without removing one from my truck.
For the 53/ the size is 3/8" -16 x 3/4". I'm pretty sure my 51 seat bolts are bigger than that.
If no one else comes up with an answer, I'll go take one out to measure it.
Thanks everyone, I did some testing this morning and found that they are 3/8-24F. My 49 and the 52 are the same.
Mid-Fiftys sells Seat Track stainless steel bolt kits, and they claim the bolts are the same 1948-56. I think I will order a set ($7) to see if they fit.
Meanwhile, I just chased the treads with a tap and then coated a bolt with anti-seize and filled each hole so I can clean the rest of the cab.
Most make the Allen head and I have seen flat faced countersunk Phillips screws listed as replacements although they are noticeably different if going for a restoration
I believe Roy Nacewicz has the correct door hinge screws, as they were used for other things on older Ford cars. They won't be cheap!
Roy Nacewicz Enterprises Ltd - Ford Bolts
Comparing them to my 55 chevy I dont think the Ford ones are that much different. As usual the chevy stuff is everywhere so price is low.
https://www.yearone.com/Product/1955-57-chevy/dm258
I thought maybe the extra hole was for the right hand drive cabs sent to other countries.
