Wastegate or EBPV?
Wastegate or EBPV?
99 F350 7.3L SRW. We have been having some incredibly cold days lately (-20 right now), and I've noticed when taking off, I can hear a "hissing" noise under acceleration. I say hissing because I can't tell if its a vacuum or a pressure leak. Once I let off the accelerator, it goes away and may or may not come back when I hit the accelerator again.
I am trying to figure out if it could be the wastegate relieving or the EBPV sticking. I did stumble across a code on my reading that said the backpressure was abnormal (P0470), but it wasn't enough to set a check engine light.
Anyway to check to see what is going on without dismantling everything?
The 0470 code indicates an EBP sensor malfunction. This may truly be the EBPV sensor, a plugged or rotted sensor line, possible wiring damage...
I don't believe you'll ever hear the wastegate open on these trucks. Did you retrieve that code from your truck with a scan tool?
For a start, attached is a link to Trey's video on cleaning the EBPV sensor and line.
gclackey
02-01-2000 08:36 AM
