66 F250 Radius Arm Bushings
Old 02-15-2015, 06:03 PM
AubreyA3's Avatar
AubreyA3
AubreyA3 is offline
Installed new radius arm bushings. I bought them locally, but you can find them online for around $17 without shipping.
Old 02-16-2015, 11:53 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
Noticed the driver's side bushing has split on my 65 and been putting replacing off, video makes it look easy, to a certain extend, gives me some incentive to take on the project. Thanks for the 'how to' video.
Old 02-16-2015, 12:38 PM
AubreyA3's Avatar
AubreyA3
AubreyA3 is offline
There are a lot of 'real' videos out there on how to replace them, so I didn't go into a big video production. I just wanted to highlight the big items. It's not that bad really.
Oh... the radius arm nut and the lower spring nut both use a 1 1/8" wrench. The lower shock bolt uses a 3/4" wrench.
Old 02-16-2015, 02:25 PM
daveengelson
Replaced the bushings many years ago with the front disc upgrade; however, done during assembly and recalling disassembly process somewhat vague over the years, along w/ other 'Senior' moments. One reason that I have not been motivated is the thought of dropping the I Beam so decided to give it a try w/out although probably disconnect the shock. Called local Napa store and they will have the bushings with next day or so. Thank you, video got me motivated.
Old 02-20-2015, 02:24 PM
Marky48170's Avatar
Marky48170
Marky48170 is offline
65 f250, 67 f100, 76 f250
I did it that way too, but while your add it you might check the pivot bushings and king pins. !!
dogohio
08-21-2013 09:28 AM
custom1106
06-29-2012 11:03 AM
topfisherman
1978 - 1996 Big Bronco
06-10-2004 10:48 PM
fordtrkfool
07-15-2003 10:01 AM
Toy man
09-18-2002 07:43 PM
Quick Reply: 66 F250 Radius Arm Bushings
