Back Again misfires cylinder #3 and #8
so now that I got the brakes figured out thanks to you guys figured id come back with my new issue. trucks throwing codes for cylinder 3 and 8 misfire. I pulled the plugs and both were covered in oil and cylinder 8s electrode was literally gone. so I replaced the plugs and within 5 miles it was missing again. so I replaced all plugs, all wires and coil packs. cylinder 8 plug had fouled out. need some advice here. its a 4.6l 99. I have a mild exhaust leak where the manifold connects to the downpipe. but not bad enough I feel it should matter. it runs rough until about 3k rpm and then it kinda straightens out.
If you have oil on the #8 plug, something else could be wrong. If #8 had/has been misfiring for a long time, you have been spitting fuel down that side cat.
You need a competent mechanic to inspect the plugs. There could be multiple reasons for it being wet. How long did you drive it before changing the plugs when it first threw the codes?
Just the threads, and the electrode. The well was not submerged or full. And I have no clue how long it's been missing, I bought it from a friend. I changed the plugs as soon as I got it the 10 miles home, I'm going to punch the cats out this weekend and see if that helps. I know they're getting way hotter than they should.
If the cats are bad you will almost always get a code for that .The rear o2 sensors on both sides monitor that.....that is all they do. It will be a "below threshold" code. Be sure you scrolled thru all the codes when you checked them and see if that is in there. Might want to run a compression test on #8.
O.K. Hill, before you go trashing your cats, lets walk through this:
1. Wet spark plugs on EACH bank: 3rd back on driver side (#3) and 4th back on passenger side (#8).
2. Changed plugs and truck starts missing again very quickly (5 Miles).
3. #8 plug still has wet electrode area and threads.
4. There IS a code for something below threshold .
O.K., I'm far, far from knowing much about the 4.6L (I struggle enough with the 5.4L) but for the group to come close to helping you, we need ALL the codes that you have received. I know this may be a pain, but there are folks who come here with a WEALTH of knowledge. For them to help, they need to know what codes you are receiving. If you can, don't just throw parts at it, or make stuff inoperable.
If anything, the wet plug COULD indicate 1. Bad valve guide seals, 2. STILL not firing coil and wire, 3. Stuck fuel injector on #8, 4. Bad intake valve, or possibly more. A non firing coil and wire CAN cause the build up you saw when you first pulled #8. You very well could have a destroyed cat on that bank if enough raw fuel has passed through. But if you trash it, you will have a constant CEL due to the rear O2 sensors reading high.
First thing I would do is swap the wires for #8 and say #4. Same length, go drive and see what happens.
