My overdrive light on the shifter handle started blinking today. The check engine light did not come on. The tranny seemed to shift fine. Hard down**** from 2 to 1 just when i come to a stop. doesn't seem to go into overdrive.
The OD light is to the transmission what the Check Engine light is to the engine. After it has been flashing there should be a trouble code stored that will lead you in the right direction to fix it. Get it scanned for codes before anything else.
Autozone said that they can't diag tranny codes. I setup an appointment with the local dealer. $90!!!! just to diag. I am still going to look for a cheaper alternative.
Here the dealer likes to get about double (175.00) for a reading.
Does anyone have a good suggestion for a excellent reader. I figure at 175 a pop, it won't take me long to recover the investment providing I can use the reader on multiple vehicles.
Chances are you aren't going to like the outcome. Last time my O/D light did this is because of a malfunction in the tranny. A pump pressure code. The tranny needed a rebuild.
If I can make a suggestion I think it would be better to take it to a Ford dealer rather than a transmission shop unless you know of one that can trust without a doubt. I have heard lots of stories about transmission shops not diagnosing minor electronic problems but instead wanting to do a complete rebuild.
Yes I'm biased because I work at a Ford dealer but I honestly feel
we are better trained to diagnose problems.
Let us know what you find out
And the tranny runs fine for up to 2-3 minutes. Then in goes into hobble mode. hard downshifts and no overdrive. I am assuming I have a E4OD. I had heard some other numbers, just not sure.
Went to shop. They found a 2-1 shift error, reset it. We took it out for a spin around town. Never popped up. I drove it for another 50miles today. Never a problem.
