Help !! 93 f250 towing capacity
I have a 93 f-250 extra cab 7.3l non-turbo diesel. 4.10 rear-end. I can't find a table in my owners manual that gives me the GCWR or the max. trailor weight so I can figure the max. towing capacity. None of the tables are for the diesel engine. What is my towing capacity? Thanks
I the GCWR should be 20,000? The GVWR is 8800lbs ?
Your truck is probably 6700 lbs or so with you and fuel. So you have about 13000 left before GCWR max.
But weight on the rear axel may limit you a bit.
The goods news about the 93 year, and I assume similar years, is they are light. If you do the math the 3/4 ton is really ~ a 1 ton.
8800-6700~2000 lbs not 1500 lbs.
Bad news is the no-turbo units will not break your neck with the acceleration to say the least.
The 1/2, 3/4, or 1 ton designations no longer have anything to do with weight carrying capacity. You have to go back to 1950 or so to find a 1/2 ton truck that hauls 1/2 ton.
BTW, I have an 83 Ranger that can carry 1400 pounds and a 73 F250 that does 3700 pounds (GVWR - weight on pink slip). I don't think you'd call them 3/4 ton and 2 ton (respectively) trucks.
kcox1228
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
11-21-2015 07:30 PM
qflyer
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
26
01-17-2015 07:10 AM
crossedcannons
1999 to 2016 Super Duty
12-19-2014 08:41 AM
