Check engine light and funky boost guage
noticed the other day when I went to leave a job site my Check Engine Light came on but the truck started fine and seemed to run normal. while cruising down the highway I noticed that my factory boost gauge was showing 35psi and fluctuating between that and around 10. looking at my H&S it was showing normal boost readings for the current driving condition, when I came to a stop the H&S would show 0psi but the factory one would fluctuate between 0 and 35-40psi I can tell the turbo is not spooling at all during this time. if I take off from a stop with the gauge showing 35 the engine sounds louder than normal at first take off compared to when the gauge is reading normal. I haven't gotten a change to get it in my shop yet to look it over but does the dash gauge read from a different sensor that what my H&S is reading? Truck is an '11 F250, deleted both EGR and DPF with H&S tuner. I checked codes and all I have is P06A7. any advise as where to start?
X2.
Even though you are deleted, I'd flash back. Start it at idle and see the guage and run for codes.
