Yes I bought cab corners front and back both sides, but on the front passenger side I just made a patch panel wasn't much affected area.... on the outside.
Hey Justin,
Your cab is looking good! The cabs take the most work - hang in there - it goes a lot faster once you get past the cab. We had to replace our door pillars - tricky. We didn't have much luck with sheet metal parts fitting from the major suppliers so we got our replacement parts from another member here who makes them - Reamer. They actually fit.
Good luck up there in Norcal - You are getting there.
