hub covers + stripped bolts = no more work for me
The easy-out method didn't work out so well. Now I have 5 very nicely rounded screw heads in the hub cover. Perfectly executed. Has an Easy-out EVER worked in history of man? Must be an ID-10-T error....
Looks like I'll have to resort to the drill method.
Which probably means that I'm in for new hub covers and potentially new brake hubs. Considering that the brake hub surface rivals that of a 6-foot swell set off the cost of Hawaii, probably not the worst choice in the world.
Amazing how everything comes to a grinding halt over $3.00 bolts.
Crazy is relative, depending on who you ask, I'm way beyond.
Left hand drill bit's were MIA. I did attempt a couple of other branded easy-outs with no success. Busted out the 3/16 metal drill and the hub covers were off in 15 minutes although they will need to be replaced.
Twigs called it. Once the covers were off, the remaining portion of the bolts unscrewed by hand.
Thanks for the input. Hopefully the rest of the install will go well.
mike
mike
Buyerz
09-30-2012 10:19 PM
Home Solutions
01-05-2005 06:54 AM
88grandmarquis
12-18-2002 09:48 AM
