Should I grind and finish these welds or leave them be???
Old 02-27-2015, 05:30 PM
AXracer's Avatar
AXracer
AXracer is offline
If you use a liquid with less surface tension than water (gasoline, alcohol, acetone). you should need very little/no pressure at all.
  #62
Old 02-27-2015, 07:13 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
The pressure test with water vs vacuum serves several purposes......
This is for a blower, and will see possibly 20 psi, 50 psi gives me a safety factor of 2.5, which I like.
Using water with air pressure vs just pressure keeps it from EXPLODING and sending shrapnel everywhere should something happen. Pressurized water does not store as much energy as air or vapor.
Water pressure will also bead up at any leaks, I can wipe it off, and immediately hit with the welder, and move on to the next without having to unload/reload. Or I can mark them pretty easy if I so choose.
Being able to weld it under pressure is also the reason I am choosing to use water versus alcohol or gas. I just don't want to have to deal with the vapors should I find some spots needing welded.
  #63
Old 02-27-2015, 08:22 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Well, I didn't vote on the original topic of this thread, but I really like the look better since you ground the welds.
  #64
Old 02-28-2015, 03:06 PM
clintonvillian
  #65
Old 02-28-2015, 03:07 PM
clintonvillian
Pretty much finished on the intake until I am closer to final assembly.
Should I grind the header welds too???
Next up is the Supercharger collector and mounts.
  #66
Old 02-28-2015, 03:18 PM
blackfords's Avatar
blackfords
blackfords is offline
I think the weld is the jewel of the workmanship
emeraldcoupe
15
05-09-2015 08:21 PM
65fordguy
09-19-2010 02:42 PM
ranger429
1978 - 1996 Big Bronco
09-29-2008 02:15 PM
Archion
General Automotive Discussion
03-22-2008 12:16 PM
jorlee
1983 - 2012 Ranger & B-Series
10-24-2006 10:09 PM
Quick Reply: Should I grind and finish these welds or leave them be???
