Man am I having a hard time finding new water pump bolts for a 460,called summit ,they were lost.Mine are old and craped up.I was hoping to get new.I researched reviews with no luck ,any one cross this hurdle.
^ That is what I do also. Try finding a set of exhaust manifold bolts ANYWHERE.
I supposedly purchased the last set of bolts for the 460 from Ford. They wanted almost $20 a bolt. Bolts cost more than both exhaust manifolds. I took those bolts to a local fastener warehouse that had isles and isles of bolts. I matched them up with grade 8 bolts as closely as I could and returned the rest to Ford. I ended up using Fords studs where needed at $20 each.
