What are people using? I know it says use conventional oil but that's not easy to find in the OEM weight. Anyone had any issues running synthetic or non-oem weight?
Check your local Tractor Supply. They have plain oil.
When I called Eaton before I installed my True-Trac, the engineer said NOT to use synthetic.
I don't know why that is, but I did what he said.
did you end up using the TS Traveller oil? Any complaints?
