changing spark plugs on 97 F150 4.6L
Old 07-21-2003, 10:26 PM
sjenkins's Avatar
sjenkins
sjenkins is offline
For all you guys out there with the 4.6, how hard are the spark plugs to change? Is it worth doing yourself or are the hours of cursing worth taking it to a mechanic.
Thanks
SJ
Old 07-22-2003, 03:19 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I took mine to a mechanic after seeing the mess I had to go through to get the plugs out. He said the front ones weren't too bad but the rear ones were a nightmare, I guess he had to remove the plenum and move some other stuff out of the way to get them all out. If you have alot of patience I would say give it a try and save yourself some money.
Old 07-22-2003, 06:02 PM
byo71's Avatar
byo71
byo71 is offline
i helped my buddy with his (or rather, did it for him). its not bad if you have a few different sized extentions and a universal joint.
Old 07-22-2003, 08:39 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Hi SJ and welcome to FTE
At the top of the forum is a thread on replacing your plugs. There are instructions and lots of tips from the other guys on here that have done the job.
Be prepared to have a few hours to do it the first time you try.
They are a pain but not as bad as they look.
Get a quote on the job if you take it to get it done. Last week I got paid 1.1 hours to replace plugs on a truck like yours. Flat rate has come down. It used to be 3 hours I think.
Old 07-23-2003, 07:19 PM
03f150man's Avatar
03f150man
03f150man is offline
i replaced my wires as i replaced the plugs on my 97 4.6. so i dont know how long it would take to just replace the plugs but plugs arent too difficult except for the #4 (firewall passenger side). The plug wire connector spacers are a pain and take some time. Racerguy did the plugs in an hour, it would probably take me 3 hours but i like to go slow and savor the experience. if not in the tips above, remove the tires and lower the truck near as you can to the ground. this really helps if you an amateur and less than 6 foot.
Old 07-24-2003, 12:13 PM
peterbilt's Avatar
peterbilt
peterbilt is offline
Racerguy,
You deserve 3 hours rate to change plugs. Even if your use to it, 1 hour seems like you have to rush things.
Pete
Old 07-24-2003, 04:47 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Once you've done a few sets 45 mins is about all it takes....as long as you dont run into any snags.
Fulford
1997 - 2003 F150
02-01-2013 06:51 PM
kdmiller
1997-2006 Expedition & Navigator
08-13-2011 10:32 PM
reamer
2004 - 2008 F150
05-04-2011 09:20 AM
tcparry
2004 - 2008 F150
03-01-2007 01:54 PM
johntucker09
2004 - 2008 F150
02-08-2007 02:37 PM
Quick Reply: changing spark plugs on 97 F150 4.6L
