94 trans white smoke
Old 01-29-2015, 10:23 AM
FordRun's Avatar
FordRun
FordRun is offline
truck has not been sitting up and yes I have to keep adding AF once a week and I have not seen no leaks only smoked when starting up after driving it go away . thanks for all replys
Old 01-29-2015, 10:37 AM
rugermack's Avatar
rugermack
rugermack is offline
Take vacuum line off of tranny and see if fluid runs out
Old 01-29-2015, 11:19 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,172 Likes on 926 Posts
I am quite certain a F150 could not be ordered with a C6 in 1994. The transmission has to be a 4R70W or an E4OD. Both are 100% computer controlled with no vacuum connection to the engine.
I do know of a few F350s with C6s up to 1996/1997. Seriously doubt the OP has a C6 in this truck unless someone did a swap.
Old 01-29-2015, 12:35 PM
Spktyr's Avatar
Spktyr
Spktyr is offline
If you have to keep adding coolant regularly and there's no sign of where it is going - then yes, bad headgasket, cracked head, cracked block, etc., are your options - unfortunately.
Old 01-29-2015, 12:44 PM
FordRun's Avatar
FordRun
FordRun is offline
ty for the for reply
I had a feeling that was it.
ty
Old 01-31-2015, 09:26 PM
FordRun's Avatar
FordRun
FordRun is offline
i had few people tell me to put some seal in radiator that seal head gasket.
I don't have funds to have replace so has anyone ever tried this before? thanks
Old 01-31-2015, 09:41 PM
Mike1's Avatar
Mike1
Mike1 is offline
IMO youd be better off to tear it down and replace the gasket. With the sealers most of the time you have to flush all the coolant and run straight water then you add the sealer to the motor and you have to drive about 500 miles before you can drain it out and replace the coolant. Not something you'd really want to try in the middle of winter.
Old 02-07-2015, 12:32 AM
FordRun's Avatar
FordRun
FordRun is offline
had truck in shop today. they did few test. they said head gasket seem be ok. they said they did find intake manifold leak. I have wait till they get time do it.
Jeepers2003
16
07-05-2011 08:58 PM
rednek01
6.4L Power Stroke Diesel
32
11-29-2007 09:57 PM
weldingfreak
02-12-2006 03:10 PM
78f3504x4
04-30-2005 05:21 PM
ceprice
4 Cylinder Engines
09-28-2004 09:13 PM
Quick Reply: 94 trans white smoke
