2015 head lights
Since nobody has responded I'll throw some of my thoughts out there, it depends what you want to spend.
On the low end you could get cheap PNP HID from ebay, have a ton of foreground light, blind oncoming drivers, and poor distance lighting. est cost <$75
On the high end, purchase some of the 2015 LED headlight assemblies from a dealer and swap them out, might require some harnesses or wiring mods. could run over $1200, maybe $1500. Not sure if HID are an option on the 2015, if so still might run over $1200 for headlight assemblies, bulbs, ballasts, wiring.
Somewhere in the middle you could get some RX350 or FX-R projectors and some decent D2S bulbs and ballasts, some JB weld and do your own retrofit conversion. You'll have to cannibalize the headlights on your truck or buy some sacrificial halogen headlights. Probably the best bang for your buck but a lot of work. Unless you have a pro retro-fitter do it, then your up to a pile of money again.
You could also add some decent projectors but not sure where you would put them without something like a brush guard.
James Wagoner
43
11-13-2017 04:33 PM
kengarchow
1999 to 2016 Super Duty
04-25-2008 06:51 PM
