Long crank and now have dtc codes
Old 01-25-2015, 07:56 AM
cory5517's Avatar
cory5517
cory5517 is offline
05 f350 6.0 with 64k miles with p0263- cylinder 1 contribution/balance and u1900 network. Truck took longer to crank and when it turned over the truck acted like it wanted to die but didn't, idles great and runs great. Anybody had this problem with a solution? Thanks in advance
Old 01-25-2015, 08:00 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I would let it warm up fully, clear the codes, and try restarting it. Be sure to retest for codes at that point. Has it ever had an STC fitting update on the HPOP done?
Old 01-25-2015, 08:05 AM
cory5517's Avatar
cory5517
cory5517 is offline
I bought the truck 2 months ago so I'm not sure about sct fittings. I'm new to the 6.0 so what and where are these sct fittings?
Old 01-25-2015, 08:11 AM
npccpartsman
Very top back of the motor behind the turbo under a cover. Lots of information in the forum about it. You need something to read live data. Smart phone apps with the right adapter.
Old 01-25-2015, 08:14 AM
cory5517's Avatar
cory5517
cory5517 is offline
I've got torque pro on my tablet, can it read live data?
Old 01-25-2015, 08:21 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
I think torque pro can even run a few tests but I am not shure.
Old 01-25-2015, 08:37 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
It sure can. Do you also have the bluetooth OBD adapter?
Old 01-25-2015, 08:40 AM
cory5517's Avatar
cory5517
cory5517 is offline
Yes I used torque pro to pull these codes
Old 01-25-2015, 08:52 AM
Money-Pit's Avatar
Money-Pit
Do you have the ICP psi and IPR % gauges on it? If not, link below may help.
https://www.ford-trucks.com/forums/1...and-using.html
Old 01-25-2015, 09:04 AM
cory5517's Avatar
cory5517
cory5517 is offline
Icp is hpop right? I have ipr% and hpop psi
Old 01-25-2015, 09:11 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Yes thats it
2006 F350 4X4
Old 01-25-2015, 09:14 AM
RideDiesel88's Avatar
RideDiesel88
RideDiesel88 is offline
Ya the icp sensor monitors the ipr pressure. Ipr is what drives injectors. Injectors are what contribute/balance cylinders. Everything works together. Check icp volts
Old 01-25-2015, 09:16 AM
Money-Pit's Avatar
Money-Pit
Try to start and report what they read.
Old 01-25-2015, 09:18 AM
cory5517's Avatar
cory5517
cory5517 is offline
As soon as my tablet charges I'll let truck warm up and report what gauges are reading
Old 01-25-2015, 10:22 AM
cory5517's Avatar
cory5517
cory5517 is offline
How do you check icp volts?
Quick Reply: Long crank and now have dtc codes
