Looking at '95, F-150, engine won't turn over, Need advice
Still say buy it. Pluck the motor out, junk the crummy smog heads, cam, intake, and take the block to a machine shop to be looked at. If they can save the block then start saving for some goodies to top off your now-rebuilt short block.
Hell I would even go to the junkyard and buy a motor just to drop in there and drive it while working on bringing the dead one back to life.
Of course that's just me...
Ok, so I have my new, used project truck.
Just a quick question before I get waist deep in it...
I have eliminated oil pump shaft and hydrolocked. No metal in oil. My question is how much torque can I use to break the crank loose with a breaker bar? Go easy on me for that question. I have penetrating oil, diesel, atf mixed together in all cylinders. Will I risk damage to the trans if using a breaker bar? Trans is in neutral too. I checked the flexplate and it appears ok. Torque converter nuts appear tight and haven't wedged up in the bellhousing. Even if it breaks loose, I expect to replace the timing chain. Oh, and the cam gear on the distributor and camshaft look good. No wear.
I apologize for what seems like a stupid question. I'm a complete underdog when it comes to breathing new life into an engine that may have been abused.
Also, do I risk damage to the camshaft if I really get to yanking on this?
With the trans in neutral turning the engine won't do anything to the trans (unless the trans really isn't in neutral and somehow it's screwed up which is keeping your engine from turning, but in that case you wouldn't need to worry about wrecking the trans anyway).
Same with the cam. If it's not already screwed up you shouldn't screw it up by forcing the engine to turn.
Ok, so lots of cranking on the crank in both directions, definitely doesn't appear to budge.
Next question now. Since I cant turn the crank, that means I can't turn the flexplate in order to remove the nuts holding the converter on. Pulling the trans isn't the answer. Can the converter slide out when I pull the engine, without damage?
Only other option I see is to drop the oil pan and look for the cause, such as main bearing(s), rod, or piston siezed in bore. Maybe by loosening as much internally, I can get the crank to turn.
However I'm not sure how tolerant it would be of misalignment. If (when, really) you twisted the trans a little before the torque converter was free it would bind things up. My guess is that the torque converter would be the weak link and you wouldn't do any damage to the trans (as long as you were reasonably careful). But that's just a guess.
Even if the trans wasn't in neutral it will still freewheel. The clutch packs can't engage unless the engine is running to provide hydraulic pressure.
You definitely can pull the trans the way you're thinking of, just make sure to pull it straight back off the converter so you don't tear up the seal.
Sounds like that motor's junk but it wouldn't hurt to pull the heads and eyeball the insides as was mentioned before...
#30
