Recall 2011-2014 F250-F550 6.7L 14E03
#421
I had my truck in - finally - for an oil change plus the reflash. The dealer is 30 miles of mostly open road driving. I zero'd the Lie-o-meter just to check fuel mileage each way. Going, cold engine, 41*F oil @10*F ambient to start out with, it was 16.7 mpg. After the reflash and traveling the exact same route plus being stuck behind the same @#$% 18 wheeler for about the same number of miles, the Lie-o-meter registered at 19.4 mpg though with a warm engine and 23* ambient. WOW!! 2.7 mpg better. Yep, at least today. Do I believe that is 'real life'? Only if I believe in the tooth fairy and Santa. Shifting 2-3 seems a little stronger and a throttle dead spot has disappeared plus the idle speed is back where it belongs at ~600 rpm instead of 900-1100 since really cold weather has been here. I was also able to get a copy of the OASIS - looks like the PO had some problems with the CAC, NOx sensors and the turbo right after it was delivered tho I've not had any.
Oh and no regen nor any low DEF warnings yet
#422
#423
2013, 49k miles and had ours reflashed while in for other maintenance.
1. Seems to be an improvement in mileage while towing. Not phenomenal, but noticeable (maybe 1/2 to 1 mpg). Today we had a decent headwind and still got just over 10 mpg (16k fifth wheel).
2. We've always had a pretty good "bark" sound on a 3-4 upshift when towing. Haven't heard it at all since the flash (crossing my fingers on this one).
3. Today while towing and running with cruise on and in tow/haul mode, the truck downshifted itself eventually to 3rd gear (running 55) to retard speed going down a pretty good interstate grade. I never remember it dropping more than one gear before, eventually allowing the truck to keep gaining speed until I intervened.
We haven't driven enough unhitched to comment on regens or bobtail mileage. Will see how it does in the longer term.
#424
#425
Someone else posted an issue like that. I am surprised that your Ford dealer has not called Tech support. Ford HQ has a bunch of engineers to help them out when they get stumped.
I am thinking on the modules that needed to get updated didn't take the update, but that is just a SWAG at this point.
#427
They have called and Ford hasn't come up with a resolution other than "you'll have to change the PCM, DPF unit, and a bunch of sensors" all for $12,000. I'll buy a Dodge before I put that kind of money into this toilet.
#428
#429
I got the letter and need to get in to get the flash done. I have a 2012 with 42k miles. Looks like I also have the dreaded radiator leak. I do have an extended warranty. I just noticed last night that I have another leak. It's coming from the area around the windshield washer reservoir on the passenger side. I can see the water dripping off of the frame rail. Hopefully, I can get this all taken care of soon. It's a great inconvenience and disappointment.
#430
Every body needs to calm down
</td></tr> <tr class="rssbody" valign="top"> <td width="88%" height="24">Some 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine and built on or before 11/6/2013 may exhibit a “Drive To Clean Exhaust System” in the IPC after completing FSA 14E03. Service Tip: Ensure to Perform a Diesel Particulate Filter (DPF) Manual Regeneration and DPF Parameter Reset to clear this message. The adaptive learn tables for the Diesel Particulate Filter (DPF) are not reset during PCM reprogramming and will need to be reset/cleared to prevent this message from being set falsely. Reset/clear the DPF parameter tables and perform the DPF Manual Regeneration with Integrated Diagnostic Service (IDS) tool by selecting the following: Toolbox, Powertrain, Service Functions, Diesel Particulate Regeneration System, DPF Parameter Reset and DPF Manual Regeneration.</td></tr></tbody></table>
#431
Calm down? Just saying it the way it is. Two brand new guys show up and complain, one of which says that a Dodge may be in his future. Amazing that those folks are never taken to task and will quite possibly never be seen again as happens so many times on a product specific forum.
Oh and my May 2010 build 2011 6.7 after Recall 14E03 was made has not even gone to regen yet in about 150 miles
#432
#433
#434
#435
Crystal
